 anchor
Posted - 25 Apr 2003 :  01:18:06  Show Profile  Visit alastairwilson's Homepage
Has anyone used an anchor with the centreboard version? If so what weight and chain would you recommend?
thanks
Posted - 25 Apr 2003 :  01:49:58  Show Profile  Visit AlisterBeveridge's Homepage
I've used a 2.5kg folding anchor with 20m of 5 mm rope. It held very well in a force 4 on a lake.
Posted - 25 Apr 2003 :  23:10:39  Show Profile  Visit DavidShannon's Homepage
Alistair,
I have a small collapsable dinghy, grapnel anchor that I use, it must be about 3kg, or so. I can't say exactly as I am overseas at the moment. It has been more than suffice for lunch stops if you want to keep the boat off the beach. I think it is important to get a few metres of chain as well - about 4m-5m. This gives the correct horizontal pull on the seabed, obviously the more the better but is more weight. Then some polypropelene or nylon rope. I wouldn't leave the boat unattended because of the way it sheers around in the wind and can drag the anchor (bigger anchor then ??). When I do leave it I have tested it with board up & down and rudder up or down but no ideal conclusion. Likewise mainsail up or down, Somtimes up with lots of kicker and flattner and it stays heading into the wind - but no mainsheet in case it drives off!!
Do you have a chandlers to talk to - it doesn't require very much weight for what I am talking about - I used the same chain to secure the trolley in the dinghy park.
This page was generated in 0.61 seconds. Powered By: Snitz Forums 2000 Version 3.4.07
