 Gooseneck fiddling resolved
Posted - 13 Apr 2003 :  04:48:08  Show Profile
Further to previous questions about boom fitting, here's a small tip: use an R-pin instead of a clevis pin on your gooseneck fitting and you will be surprised to see how easy fitting the boom becomes! The same applies to the rudder.
Another tip: there was a thread some time ago about the difficulty to get the mainsail all the way up. Just fit a parrel bead at the end of the mainsail halyard. You can then tie it to the top of the mainsail by threading a loop through the eye and catching it with the bead. That way the knot is lower that the top of the sail and you can gain a few inches.
Posted - 15 Apr 2003 :  13:32:36  Show Profile
Just a precision: I meant replacing the split ring with an R-pin, not the clevis pin itself.
This page was generated in 0.52 seconds. Powered By: Snitz Forums 2000 Version 3.4.07
