 Mainsheet mods
RichardLansdowne
Posted - 03 Aug 2004 :  13:06:36  Show Profile
I guess that there are two choices when packing up the boat- either undo the painfull gooseneck fitting, or unfeed the mainsheet and leave the boom up. Neither is particularly convenient.
Has anyone considered modifying by changing the blocks on the boom for some kind of snatch block?... ( http://www.holtallen.com/holt/snatch.html )
.... it is a bit of a pain as the current ones are rivetted on.
MarkWest
Posted - 15 Aug 2004 :  17:18:40  Show Profile  Visit MarkWest's Homepage
We usually leave the boom up supported by the main halyard and held central by a bungee chord with plastic hooks. Everyone at our club thinks it looks like a sports boat and they've christened it the Ark Royal! The snatch blocks sound interesting but are they legal?
Mark
Posted - 16 Aug 2004 :  19:18:03  Show Profile
I always remove the boom when packing up the boat; that way I can leave the mainsail attached to it. I've resolved the gooseneck fiddling by replacing the split ring with an R-pin.
Note that I remove the mainsheet as well most of the time to protect it from UV and rain, unless I know I will be sailing the next day.
DaveStubbs
Posted - 19 Aug 2004 :  19:56:54  Show Profile
Richard,
I now leave the boom on all the time. I have made a plywood 'H' shaped support that fits over the horse and supports the boom which is secured by an elastic that runs over the Boom and through the Horse to the rear D ring on the cover. The plywood has been varnished and is standing up to the weather really well.
Second innovation was to change the Goose Neck pin to a Drop Nose Pin (order by phone from Trident-UK.Com and delivered the next day approx 10 pounds.
The final gem is that we lost 2 ring pins?, the ones that hold the launching trolley onto the roadbase or front towing arm to the Launch Trolley; I discovered that these are available from any good agricultural shop (as in sells tractors etc) in bags of 5 for les than 1 in a chandlery.
If you want to cantact me I can send you a picture of our 'support' and explain how we put it together. d.stubbs1@ntlworld.com
rgds,
Dave.
This page was generated in 0.88 seconds. Powered By: Snitz Forums 2000 Version 3.4.07
