 Out Board Motors
DaveStubbs
Posted - 07 Sep 2003 :  21:04:31  Show Profile
I have just bought a stratos. Can anyone recommend a suitable outboard (size & make) for the Stratos?
Posted - 07 Sep 2003 :  22:46:42  Show Profile  Visit alastairwilson's Homepage
hi,
there was some info earlier on in the web site. I can't get it to load up.
I have bought a Honda, 2hp for £349. It is a four stroke, so uses unleaded petrol with no oil mixing. It is a short shaft and works quite well, although it tends to come out of the water if I am at the bow. It is light at 13kg and seems to have enough power.
If you need any more info, email me.
yours,
Alastair
Posted - 08 Sep 2003 :  16:25:18  Show Profile
Hi Alastair,
Is the Honda powerful enough for the Stratos? Do you have the centerboard or keel version?
Also do you find the noise level of the Honda bearable?
Posted - 08 Sep 2003 :  22:38:04  Show Profile  Visit alastairwilson's Homepage
Hi Pascal,
I have a centreboard version and I think that it is powerful enough, and seems to push us on at fair speed, although I am using it on inland lochs. I don't think it gets the boat any faster at full revs that at 3/4 qtrs.
It is not too noisy, having used a Seagull before on other boats!
THe Honda also comes with a safety cord and has a twist throttle, which were missing on other more expensive engines. I also like the idea of not mixing fuels and using a "cleaner" engine on what is in effect a reservoir.
yours
Alastair
SophieJezierski
Posted - 11 Sep 2003 :  00:59:25  Show Profile
hi all
we've got a yamaha malta 3.3hp two stroke. We went for the higher hp because we wanted the extra power for motoring against strong tidal flows - I think on inland waters you're unlikely to need that much. But on the subject of outboards - what do others do to protect the outboard in case of capsize - so far we've just kept our fingers crossed!
Posted - 01 Oct 2003 :  16:02:45  Show Profile  Visit JimWhite's Homepage
I attach my outboard to the hull with a short piece of cord. The attachment point is one of two U bolts I've fitted. Both are 15 cm from the bow end of the gunwales. I use the U bolts ( bottom of the U at the top ) to tie onto my pontoon.
Jim
This page was generated in 0.83 seconds. Powered By: Snitz Forums 2000 Version 3.4.07
