 Dropping the Genny
JamesThomas
Posted - 02 Jul 2004 :  21:01:13  Show Profile  Visit JamesThomas's Homepage
Having just survived the '04 Nationals can anybody help with any tips about dropping the
gennacker in a force 6? We only tried twice and
then gave up. Both times it fell into the water
and we had great trouble retrieving it.
Is it only possible when sheltered by the main?
Are we not doing it quickly enough ?
Any suggestions ?
Stratos 273
Posted - 06 Jul 2004 :  13:28:58  Show Profile  Visit DBurnett's Homepage
Here's what we do..
Both Hoists and drops are a two person job..
Hoists.........
Helm bears away onto a run while crew moves in to boat to get the kite uphaul.. She passes me the sheet... As she hoists the kite I pull the sheet taught to keep the sail from tying itself in knots and also to prevent it from powering up when we may be unbalanced. When the crew has cleated the halyard, she calls to let me know it's cleated and I allow the kit to fill, pass back the sheet and Start to power up the boat by heading up.. the ammount of heading up depends on space and wind strength.
Drops....
A reverse of a hoist...
Helm bears away onto a run... crew passes helm the sheet and heads for the downhaul. When she's ready to drop the kite, I haul the sheet taught to knock the power out of while she pulls the kite downhaul tight.. THEN.. it is uncleated.. and she pulls like hell on the down haul and I allow the sheet to get pulled into the sock.. then crew prepares the jib and gets ready to go out on the wire..
The success of this procedure hinges on good communication between crew and helm, and also on the downwind angle after a bear away.. if you can hide the kite behind the mainsail you will get a controled hoist and drop.. if the kite is full and exposed there is high chance of you going trawling..
Biggest tip is to bear away before a hoist or a drop.
Dave B. Stratosfaction (255)
JamesThomas
Posted - 06 Jul 2004 :  20:41:30  Show Profile  Visit JamesThomas's Homepage
Hello Dave
Many thanks for the tips I'll give them a try
next time we sail.
Jim Thomas
Stratos 273
Posted - 08 Jul 2004 :  09:48:24  Show Profile  Visit DBurnett's Homepage
Hi Jim,
My pleasure... let us know how you get on..
This page was generated in 0.94 seconds. Powered By: Snitz Forums 2000 Version 3.4.07
