 Laser Rope Kit
Brian George Posted - 06 Jul 2008 : 17:43:04
To those members who have purchased a Laser Stratos second hand the attache rope kit list may be of assistance :-
Main sheet 1 x 9.0 metres 9mm 8plait matt white
Jib sheet 1 x 7.0 metres 9mm 8plait white
Genniker sheet 1 x 12 metres 6mm 8plait matt blue
Cunningham part 1- 1 x 4.0 metres 5mm 8plait p/s Lime
Cunningham part 2- 1 x 1.5 metres 4mm 8plait p/s Lime
Righting line 2 x 2.3 metres 4mm 8 plait p/s Red
Righting Line Shockcord 2 x 1.5 5mm Shockcord Blue
Centreboard Line 1 x.75metres 8mm 8plait pre-streched
Toestrap Lashing 8 x 0.6 metres 6mm 8plait p/s Black
Toestrap shockcord 2 x 0.8 metres 5mm Shockcord Blue
Lashing 1 x 0.8metres 3mm 8plait standard Polyester White
Genniker Sock Lashing 3 x0.2 metres 3mm 8plait standard Polyester white
deswift Posted - 07 Jul 2008 : 22:42:42
Yes, it's the same diameter rope, but the length you use (or where you tie the stopper/ball determines how far the pole extends.
pcarter Posted - 07 Jul 2008 : 06:28:35
If I remember correctly, the gennaker tack line is the same as the halyard. Have a look at http://www.laserstratos.org.uk/forum/topic.asp?TOPIC_ID=447
bty151282 Posted - 06 Jul 2008 : 21:44:39
Can anyone advise on the length and diameter of the gennaker tack line, which isn't included in the rope kit?
Helen
Stratos 872
This page was generated in 0.23 seconds. Powered By: Snitz Forums 2000 Version 3.4.07
